2005 Mustang GT Roller and KB built motor
jbozz601
Meridian, MS
Not sure if i can post this here, if not let me know and ill post separately in the parts page.
2005 Mustang GT for sale as roller and motor. Will not part the car out by part bases. Meaning I won't just sell a certain part off the car or motor. Car is located in south Mississippi. Can be reached via text 6oh1- foe7nine-75onethree for quicker response. CAR DOES NOT HAVE A TRANS, SOLD TRANS EARLIER IN YEAR. Motor ran fine before i decided to sell the trans and part the car out.
Selling the motor complete supercharger to oil pan WITH ecu and harness if needed. $7500 obo
Motor build list. 25k miles on motor build.
-Teksid block
-Full Manley rotating assembly
-8.9:1 compression pistons
-Stage 3 ported heads
-Stage 2 comp cams
-Kenne bell 2.4 supercharger
-16psi supercharger pulley
-2-step
-60lb injectors
-BBK twin 62mm throttle bodies
-ARH longtube headers
-ARH catless h-pipe
-NEW BRISK plugs
-NEW FEL-PRO head gaskets
Roller has 39k miles on it. Car is 9/10 with normal scratches not noticeable from a far. Interior is 10/10. The leather has zero seat wear and the back seats are flawless. Has clarion indash CD player with aux import and has alpine tweeters in the a-pilafs and alpine door speakers. Has boost gauge and AFR gauge in the center A/C ducks. Parts have 25k miles on them. Roller is priced at $8500 obo
Roller build list
-4.33 gear
-Full spool
-C-clip eliminators
-Strange 35 spline axles
-Full BMR drag suspension
-Aeromotive stealth 340 fuel pump
-Kenne bell boost-a-pump
-Be cool radiator
-3" magnaflow magna pack cat-back
-Fully adjustable rod ends
-BMR extreme anti-roll bar
-Slotted and drilled Baer decelerators front and rear
-EBC red stuff pads front and rear
-15" race star bigs and littles
U need to,host the pics somewhere or upload them to,the site.
U cannot link email attachments.
If u have the appropriate pics. However, probably better off to post the motor seperate and in the parts forum.
jbozz601
Meridian, MS
2005 heads ported by MMR. Blower is a 2.4. Manley h beam, manley crank, manley 3-valve pistons also, Teksid block with the water passages drilled for the 3-valve heads, comp beehive spring and comp stage 3 blower cams with phaser lockouts, ported and polished the throttle body also.
<bump>
The01Cav
Looks like a great deal for someone. Good luck with the sale!
