strongs_2009
- Joined
- May 13, 2010
- Posts
- 35
- Reaction score
- 0
After alot of thought about this I am putting it up for sale to move onto a bigger vehicle project I have in mind. This is a awesome car I have loved every min of owning it. Ok on to some of the mods. The 865 and 819 are with out nitros.
Whipple 3.4 (25lbs boost) 3 pulleys
IW 10% lower
Whipple 160mm throttle body
Whipple cold air
Fore fuel rails
80lb injectors
Upgraded fuel lines
3 gt40 fuel pumps
Fore triple pump hat
Ported heads and lower intake by foxlake
Oliver Rods
Manley Piston (stock compression)
Spec stage 5 clutch
Cobra Jet and Ford lower springs
QA1 rear shoccks
completely done Steeda suspension
Moser Fab 9 rear end
Alcoa rims (street) Bogarts (track)
Shelby 6 piston brakes (stock rear for track)
Snow stage 3 meth kit (all the upgrades)
NX nitros kit (75shot)
C2 guages
Line lock
WOT box (2step - no lift shift)
Exhaust - Full bassini exhaust
Cams - ford high lift cams
Injectors 80s
Kennybell boost a pump
Theres a quick take on what on this. I have all the receipts to go along with it. But im asking $48,000 OBO. It has around 9200 miles on it. This motor in it now has never seen the track. When I did the rods and pistons and all this I purchased a new block also so that the motor could be put together with out the car ever haveing to really be down at the shop for that long. So the actual motor in there now only has somewere around 2000 or so miles on it. You can email me at [email protected]. If you would like more pics just ask I have a ton more I can post.
IW 10% lower
Whipple cold air
Fore fuel rails
80lb injectors
Upgraded fuel lines
3 gt40 fuel pumps
Oliver Rods
Spec stage 5 clutch
QA1 rear shoccks
C2 guages
Line lock
Injectors 80s
