Blacked out rear lights :-(
N2STC
The former owner put some black coating on the taillights and high mount stop. I'll admit it looks cool, but dims the brake lights too much in my opinion, causing a hazard. I replaced the high mount stop with a cheap LED one from Amazon. Not bright enough. I just ordered a LED bulb for the high mount stop from super bright LEDs. Can anyone suggest a way to remove the black coating? Perhaps I could just take it off of the center stop light. Other suggestions are also welcome.
73,
Stan
Have u tried buffing it off with a light compound?
73,
Stan
If the tint is spray on acrylic (and most are) alcohol should dissolve it without damaging the plastic. Here is a video using throttle body cleaner that works really well too.
Iceman62
Bullitt 6005
NE
Also, if you think it will help, you could go into auto part store, grab a can & read the label. Guessing they have removal steps on the can...maybe?
dustyn83
Had success using brake cleaner in the past. It didn't damage the taillights.
tjm73
of Omicron Persei 8
Rush, NY
Go to a pick-your-part junkyard and get a pair of taillights out of a V6/GT. Or eBay. Done. Sell your tinted ones. Someone would probably buy them.
N2STC
Update: Tried carb cleaner with acetone on the middle stop light. No effect. Will try rubbing compound. Maybe if the replacement LED bulbs are bright enough, I can just leave it. I appreciate all of the suggestions.
gbstang
go to your local auto parts store, get a headlight restoration kit, it has the mandrel for your drill and the fine grit sand paper to redo the lights, the only thing though is you will not be able to get into those creases between the individual lenses, but I think leaving those creases black would look cool!
tjm73
of Omicron Persei 8
Rush, NY
It'll be way less work and aggravation to just swap them out. And you can sell the tinted ones to get some(all?) your money back. Just sayin......
gbstang
Not really, first you have to find a nice set, then after you part with those hard earned bucks to get them,,you have to wait for them to be delivered.. After you swap them out, you now have to wait again for someone to buy yours.. No,,just use the headlight kit to restore them, you will only have an hour or two into the job and be back in business!
MrAwesome987
Upstate SC
Literally dime a dozen in junkyards, such as LKQ. I bet you could get a set for like 50 bucks from LKQ.
tjm73
of Omicron Persei 8
Rush, NY
This. And also all the V6 cars use the exact same lights. So even buying one here and one there will work.
gbstang
Yeah, to say they are the same as a V6 car---really? LOL...
gbstang
Yeah, have seen plenty in junkyards too, they are not all that great, most are blurry from having been exposed to the elements 24/7
Its cool if you're just lazy and don't think restoring your lights are an option or doing anything on your car to save cash.. Remember: a fool and their money....
MrAwesome987
Upstate SC
They are absolutely the same taillight housing from GT to V6 in the 2005-2009 model year.
Why jump on here and start suggesting we are lazy and foolish for suggesting an alternative option, that would likely have more favorable results than trying to remove spray paint from plastic for hours?
tjm73
of Omicron Persei 8
Rush, NY
Right https://www.lkqonline.com/2006-ford-mustang-tail-lamp-assembly/-h3KjmncKKj
Left https://www.lkqonline.com/2006-ford-mustang-tail-lamp-assembly/-h4KjmncKKj
$90 bucks for a pair. My time and aggravation is worth something to me. Fucking with painted taillights to remove tint is worth a hundred bucks plus a little time or so to be done with it. Then I would sell the tinted units for $75 bucks and be $25 into it plus a little time I spent swapping them. That's easy math for me. You can do what you are comfortable with. We all do what we think/feel is the right way to do it.
R27c286ebdc9fe8b1936ad6491f17de7f
gbstang
LOL, Yeah, everybody on this forum KNOWS they are they same!! I was being sarcastic, but then you would need to read into that...comes with education I guess. I have probably owned more cars, (Mustangs also) than you have so I think I know a bit more about them.....
I am NOT suggesting something foolish, only to you I guess.. To throw away your money on a set of tail lights because only YOU are too lazy to put in a bit of work speaks volumes... Now go back to bed, mommy says adults are talking and its past your bedtime.
