Borla Axleback Repair?
Scott88
VA
The mount for the Borla axleback exhaust broke (see pic). Now its clanking around back there, moving with even the smallest bumps in the road. Is this a simple weld job, or should I look into extra reinforcement? Is this common enough where I should reinforce the other side too as long as I have it up?20200320_192346.jpg
MrAwesome987
Upstate SC
You can weld stainless with a normal mig welder and plain wire. That's likely what any exhaust shop will do.
06 T-RED S/C GT
Carnegie, PA
The mount for the Borla axleback exhaust broke (see pic). Now its clanking around back there, moving with even the smallest bumps in the road. Is this a simple weld job, or should I look into extra reinforcement? Is this common enough where I should reinforce the other side too as long as I have it up?View attachment 72062
Just an FYI, if your the original owner of the Borla axle-backs and also have your original sales invoice? Borla will replace them under warranty. Anyhow, just saying.
Scott88
VA
Thanks for the collective knowledge. Seems simple and straight forward. Just wanted to confirm I wasn't missing something?
Iceman62
Bullitt 6005
NE
Unless the other side's showing an issue, I'd just fix the broken mount. If you have an exhaust shop do the work, tell them to give both sides a once-over, for good measure.
oldVOR
Northern Virginia
While you can weld it that way, it's no where near as effective as doing it the right way.
Short cut repairs end up being short lived repairs.
  • Like
Reactions: KRS
MrAwesome987
Upstate SC
I would disagree with it being short lived. I've welded, and seen welded, many things like that with no issues.
+1
I have welded many exhausts, both SS and aluminized. Using plain shield core wire. The only downside is the weld gets a little rusty looking vs the SS pipe.
oldVOR
Northern Virginia
You can disagree all you'd like, however, the fact remains that welding with dissimilar filler will not last as long as welding with similar filler.
+1
Correct, it will rust and be more prone to cracking due to the dissimilar metals.
MrAwesome987
Upstate SC
I would be shocked if any muffler shop would actually weld that with stainless wire vs standard wire. A good weld on that with plain wire will outlast that muffler and maybe the car.
06 T-RED S/C GT
Carnegie, PA
Is the OP aware that Borla will replace the mufflers under warranty? Therefore why even bother taking his car to a muffler shop when he can get brand new replacements at no cost to him under warranty with the only exception of perhaps being required to pay for the shipping costs :shrug:
Scott88
VA
I'm not the original owner, so the Warranty won't be honored.
KRS
In my opinion if you just butt weld the hanger back together it will most likely just break again. I’d find a piece of stainless rod about 6” long and about the same diameter as the existing hanger. Have the shop bend the rod into a hook shape to fit along side the exiting hanger, overlapping the break. Then weld them together.
Coosawjack
Beaufort, SC
^^^THIS!!^^^
Rick Simons
I would be looking for the cause of the breakage; to me the repair is the easy part. did it break adjacent to a weld?
Scott88
VA
I was wondering the same thing. It looks like it broke just above where the weld stops and the "hanger" separates from the pipe. I don't remember hitting any bumps or anything that might cause the break other than just wear over time.
