Finished doing the PCV removal and catch can mods. Went to start and car started immediately, but then dies. Went into failsafe. Got codes P2104, P2106, P2111, & P2135.
The first two are basically that the ECM is in failsafe.
P2111 is Throttle Actuator stuck open. Its not.
P2135 is that the TPS readings in the ECM and gas pedal readings do not jive.
Gas pedal is not stuck.
The oblivious culprit would be the 16YO TPS was damaged when I moved the throttle blade manually when I cleaned the TB. All wires appear to be intact. Any other ideas?
