Bringing a old thread back for some conclusions. Over the winter I hooked up the innerceptor gauges up and recently after changing to a 18% OD pulley I relized my head temps were going up to 225, didnt see anything higher and then the fan would com on bringing it down to 205. So we thought the issue was with the stock water pump. I replaced it with a Electric H20 one. Then we still had the same issue. Coolant temp from 195 to 213 and head temp up to 225. Once it hit the 225 it would then cool down. I have strickly H20 in the coolant system. Going to add purple Ice as soon as I get this under control.
Then I changed the thermostat and still the same.
So today I installed a wire from the High fan relay to a ground. Has this been successfull for everyone? This way when I turn the ignition on the innercooler, fan, and E20 waterpump all come on. I know it takes a toll on the battery, but with my gauges I can monitor it. 800 Cold crank amp Braille battery. I also noticed that my IATs are running 135 around town. That is too hot for 80* weather. Hopefully running these fans will help.
