BlackSunshine
Power Downshifter
Hey Guys,
So I have noticed somehting that I don't believe existed prior to installing some underdrive pulleys. This could be coincidence but I'd like some feedback. I've noticed now that when my car is idling and I blip the throttle the headlights and dome lights (if they are on) with brighten up a bit when the RPM increases and when it settles back to idle, they will dim a bit again. Also, the heater/AC motor will increase in speed and the decrease when the RPM's settle back to idle.
My question is if this behaviour is a product of slowing down the accessory system by the UDP's or could this be and issue with the alternator/battery? I have logged my charging system through my X3 and it will show 14+ volts until the car is warmed up and then settle down to 13.5-6 but the fluctuation in the values are not really affected by RPM speed, maybe .2-3 volts. In the old days this was usually a sign of a bad regulator or what not and I'm not even sure if these cars use an external voltage regulator to be honest.
Note that I am still on the original alternator and battery from 2005. Thoughts?
Cheers.
Cheers.
