Exedy Mach 500 Clutch and Lightweight Steel Flywheel
Racer47
Doesn't have much to say
SE Wis
SOLD
Exedy Mach 500 clutch, 10 spline, part number 07802CSC, only 5000 miles and in excellent condition.
Will sell for $290. New cost is $573 from American Muscle
https://www.americanmuscle.com/exedy-mach500-stage3-clutch-kit-0510.html
https://shop.exedyusa.com/exedy-rac...e-1-organic-clutch-kit/07802csc/i-392981.aspx
American muscle calls it stage 3, Exedy calls it stage 1. Regardless of the name, its a great clutch and will take all the power that your stock block can make. It drives like stock in stop and go traffic (not grabby), slightly stiffer clutch pedal feel and rated to 500 ft-lbs. Although many here have pushed it much higher without slip.
Exedy lightweight steel flywheel, part number EF503, same 5000 miles as the clutch and also in excellent condition.
Will sell for $190. New cost is $365 from American Muscle
https://www.americanmuscle.com/exedy-race-flywheel-9604-6bolt.html
Will also include ARP pressure plate bolts for free. New cost is $20
https://www.cjponyparts.com/arp-clu...MIlYL7kebc4wIVx_7jBx2Pnw09EAQYAiABEgIfyfD_BwE
Will also include the clutch alignment tool, used clutch slave cylinder and used pilot bearing all free.
Total for everything is $480 and I will pay for shipping and paypal fees.
You can still see the part of the original paint label on the clutch disk. That shows just how little wear there is
Racer47
SE Wis
Marked down to $400 even from $480.
Racer47
SE Wis
I bought the car used. It had a spec 3 clutch that sucked, I hated it. But I was looking for a good used 6060 so I put up with it. Couldn't find a trans, got sick of the spec and bought the exedy set. 5000 miles later I find a trans local with the ratio I wanted at good price and pulled the 3650 (which I still have if anyone needs one) and the exedy clutch.
Racer47
SE Wis
It will easily take that. It's rated for 500 or 550 ftlb, and guys here have run it up over 600 without issues.
Search here, tons of good reviews, that's why I bought it
