I have to replace the two hard lines that run from the steering gearbox to the rack itself. These are the two preformed hard lines that come with the rack. You can not buy these separate from Ford, or anywhere else that I have found.
(these are not the lines coming from the pump, or going to the reservoir)
I am going to try and go with flexible hose for these two lines. Im in Brazil right now so I don't have access to anything, but want to try and order what I need while I am gone.
Can anyone tell me, with certainty, what the size of the fittings are that are on the end of the lines? I am thinking it is a 9/16 x 18, or a 5/8 x 18 thread.
If I can get the correct sized nailed down, I will use fittings like these:
http://pitstopusa.com/i-5066145-aer...d-size-female-45-power-steering-hose-end.html
or
http://www.aeroquip.cc/fbm1382-fcm1382.aspx depending on what size I need.
Thanks in advance.
Kyle
or
Thanks in advance.
Kyle
