FS: Build leftovers
09Stroker
All stock parts are from an 09 Mustang GT w/ 6000 miles
Mustang GT grill with fog lights- SOLD
Lower grill- $35 shipped
FRPP (not motive ~ 2000miles) 3.73 gears- SOLD
Stock limited slip diff- SOLD
Stock axles- $100 shipped obo
Stock rear springs- $45 shipped
Stock GT500 upper strut mounts- $50 shipped
Stock battery mount- $25 shipped
Stock radiator- $100 shipped
Stock clutch pedal assembly-$40 shipped obo
Prosport Gauges, boost, fuel pressure & water temp Green/White, includes single SOS radio mount (kind of cut up to fit my radio cage) and upper radiator hose adapter- $100 shipped obo
Forge dump 1" valve w/ various springs (this is a replacement for the bosche valves if dumping to atmosphere- used- $75 shipped
Stock spare tire never used- $40 shipped
Alcohol Injection Systems fender mount meth kit w/ Devils Own Tank & dual nozzles- SOLD
Spec 3+ 26spline clutch-new- $300 shipped
2- 3" inlet cone filters- $30 shipped for both
SCT BA3000 MAF- SOLD
SSBC 28146 Vacuum pump kit- $250 shipped
Stock upper & lower control arms- $50 shipped
Stock rotating assembly- $75 + shipping
Stock fuel rails, lines, filter- $50 shipped
Stock front sway bar- $65 shipped
Stock panhard bar- $45 shipped
Stock 5 speed shifter w/ knob- $25 shipped
I have several AN fittings, braided lines & silicone couplers leftover that I will list later.
Kuro!
Banned
Austin, TX
They look like the basic prosport gauges. The premiums have buttons for peak recall.
09Stroker
More Pictures
stangstud09
Respect my authority
Dallas
so do you have the whole 8.8 rear end? or everything i would need for the v6 swap?
09Stroker
any pictures of the clutch?
96blowncobra
clover, sc
ah ok then i cant use it... would you sell the boost and fuel press gauges? i dont need the temp and SOS mount.
