Fuel Pump Driver Module Compatibility
Bigearl
Ontario , Canada
I am using a 2007 4.6 3 V motor in a Cobra kit car. I will be using a Ron Francis standalone engine wiring system that utilizes the Ford ECM and all the sensors etc. I have to use a SN95 fuel tank for fit. I plan to use a Walbro TU229HP returnless fuel pump which is 255LPH. My question is compatibility of the 2005+ FPDM with a fuel pump that is a replacement for 2000 to 2004 Mustangs. I also believe the 255LPH fuel pump will have more current draw than the standard 2005+ fuel pump.
Any advice would be much appreciated. Earl
