Yea , clearance is minimal with this intake.Looking good man. I'd like to swap to the JPC intake on my 5.4 but I'd have to change hoods...again.
You should like these then.
I'm guessing there's supposed to be a picture here, but I can't see shit!
Damn it ! I almost puked up my tacos . Thats just nasty ! LOLHere you go.
Thanks ! Some people really don't understand how long it takes to do the custom work for something like this , custom pieces sometimes means staring at something for hours , looking at all the angles to make sure it will work . I would hate to see what the finished product would have cost from a shop .Looks good, I like the detail you put into this build
There not there yet . It will be two -8 lines coming from the drivers side , under the brake booster. The rails will connect in the rear , where they will go through the regulator , sending unit , pressure sensor etc. . There will also be -10 lines off each valve cover to two Moroso breather tanks mounted on the frame rails , under the headlights and -12 lines off the valve covers to the collectors for the crankcase evac system . All lines will go to the rear of the engine bay on both sides and return to there destination under the fenders and etc. .Agreed!
I went and flipped through your album, good isn't an accurate statement for how nice it looks! I'm curious how you ran your fuel lines, I can't tell if they are going straight through the firewall of if my eyes are playing tricks on me.
So your running both breathers and an evap system, I was hoping that's why the two fittings were coming out of the covers. Did you change anything with the baffles on the covers or leave them as is? This is exactly the kind of attention to detail that I wish I had the time and place to work on myself
I haven't yet , but the drivers side will soon loose the PCV valve . The breathers in the stock locations will vent pressure from the rear of the valve covers , drawing it from the front. The evac setup when under WOT will suck from the front. While the evac setup would draw more of a vacuum on the motor without the breathers , I fell for this application the breathers are necessary for decel and normal street driving.
One thing i forgot to add was that I did finally build some cnc alum. pcs to replace the fac vct units on the front of the heads . There is lots of room under the -12 line for the evac system now , with a full vct delete. I deleted a lot of photos from my phone on accident , but I will see if I have one somewhere .
Here is a pic my guy at the shop sent me after they were cut , I polished the grooves and rounded all the corners at home . I had some really nice pics of them on the motor , but like I said I deleted them . When I remove the drivers valve cover this weekend I will get a pic of that side installed and post it .
I see nothing...
That's funny , I see them fine . Anyone know whats up with that ? I just recently started posting them from the album to save my attachments space .He posts all his pictures in his album, I never see his links either!
http://www.s197forum.com/forum/album.php?albumid=312&pictureid=3081
