The brackets for the HE from Gords were fine. I did swap out the pump, so I had to fab that up. I also took the extra time to use 90* elbows for the hoses. I didn't want any kinked bends. I bought a long piece of hose and cut it to fit each segment.I am looking at a Gords Ford HE or AFCO HE for my KB. Did Gords have the right brackets? Did you just piece the hoses or try to find single lengths to fit?
Sorry to bump an old thread,...
Spam. Nice LP reference.
Welcome to the club... half the time we don't know WTF Roper is talking about either.Spam?
Spam?
Spam?
Definitely not the same guy...I see you responded to that. VSOP.
Sounds like a great upgrade to me. You may have to come up with some bracketry, but it's definitely doable.I think I am going to try the GT500 Heat Exchanger. It's 26" w x 6" h x 1.5" deep vs. the supplied Vortech Setrab 12" w x 6" h x ~1.75" deep.
I also upgraded to a 03-04 Cobra pump, which flows 40% better than the one supplied with the kit.
FWIW, here is a size comparison of the Gords vs the KB.
You should be in good shape then.I think the GT500 heat exchanger will work fine. The brackets from the GT500 OEM unit are a direct bolt on, so that should make the install a breeze.
I switched pumps too. The one on the left was my new one.The difference in the pump alone is pretty amazing. I was suprised at how much the 03-04 one weighed.
The pump was from a Lightning... I got it here:Don is that a 03-04 Cobra pump you went to?
I was looking at those and the prices for the Cobra pump are all over the board. Meziers has a hi-flo pump (22GPM) and then there might also be a bigger Bosch?
Does your Gords HE and the pump make a notiocable difference in heat soak?
