How To: MMR Billet Oil Pump Gear's Install
ArizonaGT
Road Course Member
Phoenix, AZ
I used one of those pistol-grip clamps with rubber jaws to compress them. For some reason, I do not have a vise at home yet :-/
This write-up was really helpful in getting me prepared for my shortblock swap. Thanks again dude.
Blazer707@TBR
Nor Cal
No problem!
Lol somehow I have had a vice for years at the house but have never mounted it on the table.
hotrod_renegade
Captain Hindsight
MANtana
Did I miss somewhere the torque spec for the T30 torx bolts that hold the actual oil pump housing together? Balls deep in this right now and I didn't see it on here nor could I find it in the online workshop manual. Does anyone happen to have that?
travelers
Eastern Pa
Here you go
2. NOTE: Oil pump must be held against the cylinder block until all bolts are tightened.
Tighten the fasteners in the sequence shown in 3 stages:
• Stage 1: Hand tighten.
• Stage 2: Tighten the bolt (1) to 10 Nm (89 lb-in), the stud bolt (2) to 25 Nm (18 lb-ft), the bolt (3) to 10 Nm (89 lb-in) and the stud bolt (4) to 20 Nm (177 lb-in).
• Stage 3: Tighten the bolt (1) an additional 45 degrees, the stud bolt (2) an additional 75 degrees, the bolt (3) an additional 45 degrees and the stud bolt (4) an additional 60 degrees.
hotrod_renegade
Captain Hindsight
MANtana
Here you go
Those are the bolts that secure the pump to the block. The torque spec I need is for the torx bolts that hold the pump housing itself together, after you've replaced the gears inside of it. Pictured here:
hotrod_renegade
Captain Hindsight
MANtana
Well shit the bed, I think that'll work! That one is for the 4.6L oil pump but I can't imagine the torque specs are much - if any - different, so I'll go with that. Exactly what I needed, thanks!
Wes06
On our cars. If the head is 8mm or less it seems 89in/lb is the magic number. Lol
Wolf302
awesome write up..will come in handy for my cam/OPG install coming up!
