Idler Pulley
GJP05
Nebraska
Is there a difference in size for the 76mm idler and the pulley on the stock tensioner? I had your tensioner installed but they said the belt was too long to run with the 76mm idler so I had them put the stock pulley on your tensioner. If there is a size difference how much of a shorter belt would I need to use the 76mm idler?
thump_rrr
Montreal Qc,
76mm is the stock idler size used on the S197 tensioner as it comes from the factory.
There are some people who change the 76mm idler for a 90mm to take up a bit of slack from the belt.
