Shawn knows 100% that the dots on the gears and the dark links in the chains were lined up....he helped Larry H install all the front parts of the motor....so I don't know???..
So this is a Larry Hays motor?
Let me guess click,click,click but fast ?One thing that is going through my head now is whenever we turn the key on there is a weird electronic noise that comes from the throttle body or what I guess is the throttle position sensor? Never recall ever hearing this before.
If you are faceing the motor from the front this is the senor on the right or left ? The one one the left would be the thottle position sensor and the one on the left is the throttle actuator motor. Also did you have to exatend the maf wires and are you sure you have voltage at the maf? In the video it sound the same as it would if the maf was unpluged. I would ck power to the TB connections and the maf before pulling of the front cover . When you turn it over for a while is there white smoke from the pipes durring or even after you stop cranking it?no, not at all. I dont even know how to explain this..... Like a robot cricket! lol not a clicking noise at all though. makes this noise for about 2seconds right when you turn the key on and it also makes another noise at the same time bye the air filter (maybe the mass air sensor makeing noise too?)
When my msf connection was bad the car would crank over like your video and sound like it wanted to start but was just floodin and had smoke comeing from the pipes even after I stoped cranking it.oh and the wire is extended from the MAFia which all of this is the same from the last setup. We have not cranked on this thing alot, why do you ask about the white smoke?
Then it stops by its self with the key on still?yes for a couple seconds.
First time was the connections were the maf had been exstended from the Procharger install but if yours just has the mafia added to the stock connector then this is a non issue for you. Second time it was not connected all the way at the maf.hmmm. what caused the bad connection and what was your solution? and yes with the key on it stops makeing the noise bye itself.
