- Joined
- Sep 15, 2007
- Posts
- 3,065
- Reaction score
- 5
JDM Engineering 4.6L 3-Valve 302E Stroker Rotating Assembly Engine Rebuild Kit
Retail $2595.00
Special Price $2095.00
Priced for a limited time only!!
Savings $500!!
Is it time to rebuild your 2005-2010 Mustang GT 4.6L 3-Valve bottom end? If your making more power than you should on your stock engine or you are looking to bring your car to the “next level,” then check this out! Team JDM now offers the same Rotating Assembly from the popular 302E Shortblockand will support 1000 HP. With the limited availability of New Production 4.6L blocks from Ford it is worth it to rebuild yours while you still can!
Team JDM is offering a complete packaged Forged Rotating Assembly Kit for the 4.6L 3-Valve Mustang engine. This package is based off the 302E Shortblock that JDM Engineering has assembled in-house since 2005 when the 3-Valve engine first appeared in production vehicles. JDM Engineering has used the 302 Rotating assembly in many of their own racing applications as well as hundreds of customers Street vehicles.
Increasing the displacement of your 4.6L short block from 281 to 302 cubic inches will create more power and torque. The extra displacement comes from the Kellogg Forged 8-bolt 3.800” crankshaft and Forged Manley Rods. The 302 Forged Pistons are standard (+.005”) bore and require only a light hone for assembly in any 4.6L block. For blocks that require a larger bore due to scuffing or wear, the pistons are available in +.020” and +.030” over size. Custom Piston Rings from Total Seal are file fit to the pistons and can support high boost applications. Nascar rated Speed Pro Main and Rod Bearings are included along with a complete Ford Racing Main bolt kit. A High Volume GT-500 oil pump is used to keep up with oiling demands of the 3-Valve VCT system.
JDM Engineering 4.6L 3-Valve 302E Stroker Rotating Assembly Engine Rebuild Kit benefits:
-Adds 21 Cubic inches of displacement to your engine
-Maximize your Shortblock's power output potential
-Forged internals able to support 1000 HP
-Same rotating components used in JDM Engineering 302E Shortblock
-Custom spec pistons keep stock compression ratio
JDM Engineering 4.6L 3-Valve 302E Stroker Rotating Assembly Engine Rebuild Kit includes:
-Kellogg 3.800" Crankshaft
-Manley H Beam Connecting Rods
-Manley Forged Aluminum Pistons (stock compression)
-Total Seal Piston Rings
-Speed Pro Main and Rod Bearings
-Ford Racing 3v Main Bolt Kit
-Ford Racing GT500 Oil Pump
JDM Engineering 4.6L 3-Valve 302 E Stroker Rotating Assembly Engine Rebuild Kit fits:
-2005 Mustang GT 4.6L 3-Valve
-2006 Mustang GT 4.6L 3-Valve
-2007 Mustang GT 4.6L 3-Valve
-2008 Mustang GT 4.6L 3-Valve
-2009 Mustang GT 4.6L 3-Valve
For more information or to place an order please contact us at www.TeamJDM.com or call 732-780-0770
Retail $2595.00
Savings $500!!
