don_w
Dyno Numbers - Who Cares?
I definitely agree on that one! That's why this device is intriguing to me.It is still better than trying to peg your rpm as these cars are very hard to peg on the throttle to rpm.
So with stick, I would put it in first gear hold the clutch down press the button, wait for it to turn green and dump the clutch and go? damm it seems like its going to be one heck of a punch.
As far as my fuel pump pegging at 5k rpms, I find it strange also.. I'm going to try swapping out my BAP for a replacement from KB.
If you wire it to the clutch switch you would not need to push a button. Just push the clutch in, floor it and when you want to launch let up on the clutch. Once the clutch comes up the 2-step will be off.
All you need is better tires to cure that.i feel like by the time you get the clutch engaged ur rpms are gonna be so high im just gonna blow the tires off.
How would you change gear ordinarily or stage? It needs to be switched separate to the clutch or am I missing something?
The 2 step is a 'must have' if you are racing with a manual trans. You no longer have to concentrate on what your launch rpm is and watch the tree. This is especially important if running off a pro tree. I don't know if there would be a benefit using a 2 step if you have a trans brake. The only benefit might be if you have a really loose converter and want to lower the flash rpm due to less than ideal track conditions. Leaving at a lower rpm will take some hit off the tires.
That's where I'm a little confused too. If you have a transbrake, why would you need this? What does it do that the brake won't?
And I'd still like to read about a success story on a 5R55S before I buy one.
So if put this on, set the rpm limit to 2800 or even 2900 (as close to stall as possible) I guess it would work without a transbrake. Probably have to hook up a switch to the brake pedal so the 2step is engaged when the brake is all the way down.
Activate 2step, stand on the brake and the gas, watch the lights, then side step the brake. I'd rather do this with a 4Krpm converer, even a 4.5Krpm.
It definitely seems worthwhile though!!!!!!
peharps i'm stupid but i don't see the two steps.
For me, regular 5r55 + tci3000. Press and hold the button to set the limit to 2900, brake, floor the gas, release the button at the same time as the brake and here it goes.
Wrong ? so only one button, one step.
I just ordered one from Summit, so I guess I'll find out in a few weeks how well it works (or doesn't).
BTW, they are backordered at Summit until 5/15, but no biggie for me... I won't even have my car back until after that.
LOL... I've been wanting something like this for a long time, so if it works as advertised, I'll be a happy camper.At a boy Don.You won't be disapointed.
You can thank me later.
I'm planning on using a momentary switch... preferably mounted on the steering wheel so it can be thumb activated. Maybe I can borrow the idea some guys used for their line locks, and somehow use the cruise control button. Or figure out how to install a new button just to the right of the cruise.Yeah that would work Andy,a switch must be installed somewhere in your case,hand held or brake pedal!!
