P2196/ p2198
scarsblonded
Colton
2005 mustang saleen stuck rich codes in both o2 sensors
New o2 sensors
New Maf
New throttle body
new pcm saleen tuned
it had long tube headers before still same problem so i got the stock manifold and cats back on
Stock injectors back on
fuel pressure test pssed
relative compression test passed
tps changed
Cars barley starts strong gas odor out the exhuast
And when it does start black smoke and sounds like its cammed
Forty61
Dallas, TX
I’m sure others will chime in but I want to clarify.. it had headers before but now it’s stock manifolds and the same tune? Is it the stock intake/MAF location?
How did your o2 harnesses look? A new sensor won’t mean much if there’s a wiring issue.
Black smoke implies a fuel issue so maybe you have a bad injector or two? I’d imagine even if they’re leaking the pump would be able to keep up and maintain the pressure for your test. That said if it’s two set of injectors doing the same thing that would suggest the problem lies elsewhere.
More info on the current setup will help and I’m sure others more knowledgeable than me will jump in.
scarsblonded
Colton
harness all looks fine for the o2 the harness was repaired due to the passenger tire rubbing and ripping the wires
redfirepearlgt
Money rides on the fact that you have the wiring harnesses for the O2 sensors backwards (bank1 on sensor bank 2 and bank 2 on sensor bank 1) assuming the harness was properly repaired.
Common occurrence in 05-09 cars after header work or clutch/trans swap. Plenty of information on this and I have written an explanation as to what takes place when the harnesses get swapped...and yes they are long enough to reach either side.
Not a betting man but this is the first place I would look as mechs always seem to think its not important to mark wiring before disconnecting.
If you want to know why use the search feature.
scarsblonded
Colton
harness plugged in correctly
Laga
Chicago
I’m not familiar with that harness. But if the problem started after the repair, then the odds are that’s where the problem is. Can you inspect the repair and make sure wires are correct? There could be a short where bare wires are touching, or wires got crossed.
scarsblonded
Colton
rhe problem been going on everysince i bought it 6months ago been at a buddys house ever since he coulfnt fix it so i brought it home the harness was properly fixed i dont think the harness is the issue
Can you be 100% sure of that?
Try switching the harnesses between the two front O2 sensors. At this point you have nothing to lose (except a few minutes of your time). If that fixes the problem, kick yourself on the butt for not thinking of it in the first place. ;)
scarsblonded
Colton
yea tried this already :/
