Paxton! Part out! And more!
randys06v6
I have a ton of stuff for sale. Doing a turbo Gen2 coyote swap into the mustang, so all must go!
Asking $5,100 OBO
Paxton Novi 2200 kit
Will include all of the following!
▪️Comes with all bracketry and all piping
▪️Upgraded intercooler to support 1000+hp
▪️Converted to blow thru system for better readings and more effective tuning (but mainly to run a badass BOV WHOOSH!)
▪️Tial Q 50mm BOV
▪️Upgraded all clamps to T-bolt clamps
▪️Dual drain lines due to HP increase (but can be closed to 1 line if not needed)
▪️Kenne Bell Dual BAP
▪️If you’re aiming for 550hp, I’ll include some 42lb injectors and a 10# pulley
▪️Whole kit is the polished kit
▪️Upgraded intake system to a power pipe system
▪️Had the novi rebuilt for routine maintenance a little less 300 miles ago
▪️Upgraded to stainless steel oil feed line (will include oil adaptor as well)
▪️Will also include the Moroso Coolant Relocation expansion tank
▪️Diablo Mafia MAF as well!
2012 Mustang GT coyote motor. Had 33,xxx miles. Tore apart to check internals etc. Was going to build it until I found a Gen2 I couldn’t pass up. Everything in pictures included. Paid $2,600. Asking $OLD. My loss is your gain.
All the following has 13,xxx miles:
Blue coil covers with black insert letters: $OLD
2016 mustang gt engine cover: $60
2016 manifold with throttle body and spacer: $100
2016 gt ecu: $50
2016 Mustang GT MT-82 transmission with clutch, pressure plate, flywheel and throw out bearing: $1,500
ATI super damper w/ac 2011-2017 Mustang GT: $OLD
Everything is located in Fredericksburg, Virginia
1E452394-6BBF-47F1-83F6-1912567A6CFE.jpeg 5E6F7263-8911-4793-AF0F-C13B3F7ECF5D.jpeg 18C9B926-967B-441C-8A9E-6D884C62F3EA.jpeg A7D989B6-4606-4C20-AC8B-29471802A030.jpeg C4E05D10-4678-4A9E-8802-C2266A7C35F3.jpeg FC1418C5-6D11-47F0-A3BC-AC6C5664B02C.jpeg 0E6F8BEF-594B-4853-983B-E8C8FE88F6E3.jpeg 89A4E69C-233D-4E56-B0FE-F222A937BC70.jpeg CE810BE0-7011-4312-8709-DB7406C6BE86.jpeg 43C693C6-0707-4217-9782-FE52A0CAF3D8.jpeg
degmidget
Curious I I have the same blower kit how does the duel drain lines help performance? thank you
please update the pics to include name/date per classified rules
