jodadejss06gt
TEAM DELETE SHIT
I'm looking for the best location to mount either a momentary push button switch or momentary on-off-on toggle switch. This would allow me to quickly switch between boost settings at the track. I'd like to possibly mount a push button on the back side of the steering wheel where I put my left hand. It would be harder to do the switching if I had to use my right hand as I normally just leave it on the shifter. Any thoughts and/or experience?
The momentary switch will basically ground one particular wire that goes to the Eboost2 and depending on settings inside the controller I can basically go to the next setting each time I bump it to ground. A second wire from the controller could be wired to go back to initial boost setting or back down a setting. The on-off-on momentary would have to be used to go down/back to initial or a second momentary push button.
Toggle
Push Button
VIDEO OF CHANGING BOOST GROUPS:
Toggle
Push Button
