Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,809
- Reaction score
- 28
At what IAT's does it start pulling timing?In normal weather, I can make two passes before the IC water gets hot enough to pull timing.
Is there any way to install a larger heat exchanger in the Saleen Supercharger manifold?
I'm not sure what the dimensions are of the inlet and outlet ports on this one, but they look much better, plus I would be worried about the plastic fittings cracking on the Saleen reservoir after hogging them out so much.
http://store.jpcracing.com/Fabricated-Aluminum-Saleen-Intercooler-Tank_p_1351.html
I only performed this experiment to determine if the reservoir was a restriction/bottle neck in the system and to see if enlarging the inlet/outlet ports on the reservoir would increase system flow. I have no intention of leaving this reservoir on the vehicle as was stated in the OP. I have a Canton battery box mounted reservoir on the way.
I didn't realize anyone made a replacement Saleen reservoir. I hope they made it a larger capacity as well as enlarging the inlet and outlet ports.
It's is a exact replica. The inlets and outlets use the oem hose I believe the id is a hair bigger. We made this inital tank for show purposes and a better seal for the cap. The inlet and outlet really ins't the concern it's the volum of fluid with the designs of this system.
We are in the works for designing a larger tank with a fuel cell cap for more capacity.
The capacity is the same...I wish they would have made it at least a little bigger. Kind of a shame to produce this and not increase the capacity while they were at it.
Any plans of developing a replacement tank for the E-force??
