Service Manual Guides
ShelbyGT07
I have a 07 S197, if I remove the rear quarter panels on the passenger side can i get to the body in front of the rear wheel before the normal air scoop to work out a minor dent?
G.T
Earth
donations are always welcome but aren't mandatory to view the guides.. i'm happy to issue a refund if needs be :)
as for the plugin, all you need is Adobe Acrobat.. the guides are PDF! nothing out of the ordinary
icebox
toronto
tr 6060
any body get the service manual to remove the c0bra tr 6060. i got a leak on the tail stock to the housing
eddieval5
katy,texas
Need an SJB pinout for the marker light and rear taillight(pass side) and how to diagnose a bad sjb
Charlie Sheen
Armed and Hammered
Infernum ubi sum
yup.. someone had enough time on their hands to go through my site and save every individual file one by one :)
And they didn't even give you credit... :thud: I've used and forwarded your site several times and appreciate the work you've done. :beerchug2:
Muztang
Park light Dissasembly
Can I take apart the whole park light assembly without heating ?
Is it screwed up or stuck up ?
are you talking about the side markers?
G.T
Earth
you can't take them apart easily.. they're glued together, and have a tab that holds the lens to the housing.
G.T
Earth
that's in your owners manual.. which model year is it?
G.T
Earth
i just added the owners guides to the site..
the fuse info is certainly in the owners guide, towards the end under "Roadside Emergencies" -> "Fuses and Relays"
