bigpappy33
11.17@126
So I have had my SLP line lock installed for about 2 weeks or so, has worked fine the few times I had used it (if you saw my line lock vid you know) so today I went to turn it on and, well, It stayed on...
So I troubleshooted about everything, disconnected the power to the solenoid, nothing, played with the switch and even tried a different switch, nothing, and tried moving the ground, no luck there either.
This leads me to believe that it has to be a bad solenoid, which is really annoying. I will give SLP a call Monday, but do any of you guys have some other potential solutions? If I toggle the switch with my foot all the way in the brake, I hear the brakes start to creak, and they slowly let out and I can move the car, but as soon as i hit the brakes again the solenoid engages again (even with the switch off).
Thoughts?
Thoughts?
