blue streak
All motor, 11.5 compression, 3.65 stroke, stock bore, ported heads, and 127600 cams. I was debating on running a stock heat range plug, or if there would be a benefit to running a hotter or cooler plug. I need all the NAsty power I can get since I'm no longer going the turbo route..
