So today I was changing my plug out and when doing so I came across one plug that had part of the ceramic missing. Im guessing it fell into the cylinder now has this happened to anyone else? Should this be a super concerned about? This happened to be the passenger side rear plug.... I was concerned to the point that i put the new plugs into the car and I did not start it and i left the car at work.... Any info would help please.
2 part dillema:
1. why did it break - possibilities:
a. excessive lean condition?
b. nitrous?
c. fault in the ceramic?
pics of the plug would help - nice tight macro shots so we can see the texture of the remaining ceramic - and/or diagnose it yourself - there are plenty of sites out there that have good pics of typical plug conditions
2. Where did the "debris" go.... That's a tough one... I've personally engines chew up and spit out some surprising things and then run for another 100K miles... and then I have seen the opposite happen too...
It is reasonably likely that the ceramic piece "shattered" into some pretty fine parts and most of it got blown into the exhaust (which would mean some went out the back and some got stuck in your cats if you still have them). In short, the damage is done... But it is possible that it cracked as you were removing it (seems less likely than while running, but the condition of the plug might help shed some light on that)...
This is a painful one... I don't have a good answer - maybe someone else can chime in with options/opinions? (looks like pfsracer did while I was typing...)
Endoscope?
Vacuum/Suction the hell out of the cylinder?
Hope for the best and start thinking about your next build?
Good luck - let us know what you find...
