Tasca Ford customer service
Fairlane514
Let me get this straight; you ordered parts, you received said parts, you broke one trying to install it, and yet you are still bashing Tasca?
I’m sure Tasca must have tampered with it AFTER they shipped it…
I am trying to give you the benefit of the doubt, but you’re not helping me out very much.
Btw; I got your private message linking all of the complaints. Not sure why you singled me out to send it, unless it’s because I called you a snowflake. I guess so, since that was the title of the message thread…
Never said they tampered with the failed part...grow up. No I didnt single you out, I sent to others who seem to be one sided.
Anytime you feel like coming to Brenham Texas, I will buy you a beer and we can talk this over, I look forward to it.
I also included the parts failure with pictures so others may benefit from the issue. It looks to me to be a manufacturing error, not Tasca. At this point always check the tiny roll pins to see if they sit proud of the surface where the bolt flange makes contact. It all happened in a split second when I began the torque sequence.
dark steed
Resident noob
Winder, GA
I’ll grant that I’m probably feeling a bit less than charitable today, everything I have eaten in the last 48 hours has exited my body rather forcefully today.
I’m glad you got your parts, I’m sorry one was faulty, and I apologize for making a smart assed comment, I know the part wasn’t tampered.
I’ll take you up on that beer, I do travel quite a bit lol
Steve@Tasca
That would be the first one I've ever seen break during installation, I checked sales history and we've had exactly zero returns or warranty claims on those phasers. I'll have to check with the manager and see what he has to say.
86GT351
Sunny South Florida
Funny. Being in Ford Service we do Phasers all the time due to the rattle noises. No issue like that at all.
skwerl
tree hugger
central Florida
I had one break like that the first time I messed with mine installing limiters. Had to buy another one to replace it. I just figured I did something wrong instead of assuming it was a defective part.
Fairlane514
Ok, I thought I might have done something wrong as well, but the second went on with the same procedure, without incident.
I can rebuild transmissions, engines,
rear ends, welding, body work etc....im not a newbie when comes to installing parts.
Im glad some of you have perfect records and never have parts failures, I envy you. Maybe its possible this was a bad part........Oh, wait, its me the new guy....it has to be my fault.
For those of you who have installed the phasers, tell me how you did it? Place it on the end of the camshaft with dowel pin properly engaged, hand tighten the sprocket bolt, then torque to spec?
If you look at the pictures I posted, you can see the new bolt was damaged by the roll pins. As soon as I began to torque it, I felt a slight grinding, stopped and said "that aint righ...." and it broke. Seconds only.
Like I said, this has nothing to with Tasca, its simply a defective part. The original parts obviously fail thats why they get replaced. Its not possible a new part could be defective, is what some of you are saying......that's a true sign of lack of intelligence and experience.
If the Motorcraft part has a warranty, what's the big deal?
Do the new phasers take careof the rattle? Or is it a placebo effect and just makes the owner happy?
From what I have been finding is VCT systems can be noisy.
I hear a light rattle, off idle in 1st leaving my driveway. Zero issues otherwise. Or should I be pulling and replacing all my phasers? Honest question.
tjm73
of Omicron Persei 8
Rush, NY
What fuel do you run? When I had my '05 GT it did exactly what you describe. I ran higher octane fuel and it 100% stopped. And I actually got an improvement in fuel economy (hand calculated, not from the trip calculator). Improved enough to make the increased price a wash.
86GT351
Sunny South Florida
Being honest it is too soon to tell. I can say of the ones we have replaced, none have come back. Yes a VCT can be slightly noisy. Some of these when they go bad sound like a Rod Knock.
Cool, thanks. Mine is just a slight ticking noise, and there are no cam timing errors. So I will just let it ride as it has not gotten any worse.
I run fuel based on use. 87 for daily, 93 on track and let the computer do its thing with the adaptive timing.
My noise is definitely not fuel related. Does it cold, pulling out of the driveway and under 1500 rpms.
86GT351
Sunny South Florida
Sounds like it very well could be a phaser or possibly a Timing Chain Guide wearing. Remember they are Metal an Plastic.
On an unrelated note. I have finally reached 5000 posts. Please send lavish gifts.
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
5k???? Rookie.....pffffft....those are rookie numbers, gotta get those numbers up!
