I just installed the th400 that came out of another s197 with just dyno time on it that I was told. First issue I noticed is that with the seperater plate on I had .430 to pull converter out till pads hit flexplate. (Way too much even with spacers or hardened washers.) So I pulled trans back out and took seperater plate out and bolted back and now we have .340
So I put .200 thick hardened washers on and pull converter forward and now we have .140 which is right between the .125 and .18 that it calls for.
Now with converter hooked up I have no First or second. Just 3rd gear.
No transbrake hooked up either.
This setup is Freakshow built th400 BTE transbrake and valvebody.
Yank converter.
JW bell,JW flex and JW crank adapter
Has anyone had issues with installing their th400 on the mod motor like this?
Did you guys have to remove the seperater plate as well and what clearances did you get?
Thanks
Yank converter.
Thanks
