Timing Chain or Motor Swap
s197jaden
Dundee, Mi
Im stuck between getting the timing chains done by a shop or just swapping the motor myself. I’ve read that the motor needs pulled to do the chains anyway so why not just swap it. just looking for input/ information. thankyou!
2008 4.0 Mustang 162k mi
If your motor is otherwise healthy, it's probably better to stick to the devil you know and replace the timing systems on both sides rather than gamble on a used motor with an unknown history.
wildlifeguy
Texas
If you get a used engine, how long will those timing chains last? My thoughts are that the most cost effective of the 2 options listed is to find a used one that has had the timing chains done when pulled. However, if you can handle pulling the engine yourself, you can probably handle the timing system yourself. I can't imagine what a shop would charge to do it. I did it and it was relatively painless, even with a cheap ebay timing tool.
