Has anyone weighed the stock parts? Just want to compare grams to an aftermarket rotating assembly.
thanks.
thanks.
that's what i was thinking. or Rich Groh.Matt, have you tried getting with Livernois?
Aren't you taking the weight thing a little too far now Matt?
500 gms would be crazy light!
All 8 of my stock rods and pistons out of my 3v weighed 26lbs. This includes piston, rings, wrist pin, rod, bearings and bolts.
I have a stock rod/piston/rings assembly on my desk, with the rod bearings in it, it weighs 1130 grams complete.
Kev
Kev
Matt, what are the plans with the motor?
Have you considered using maybe a Boss302 rod?
Well im going to stay 302. If I do a bottom end it has to be worth it for me. So everything lightened dss said they should be able to make a 12:01 ratio piston aswell. Im going to stay away from the boss piston and rods (nothing against them).
These Coyote's sure arn't cheap to build but I am looking at what I need to do to get the results I want. Head cam combo is going to be the big gain. I picked up 75 wrhp on my 3 valve on a stock bottom end. I can't wait to see what I can get out of this motor. While at Sema I found Mezire's trick new electric water pump. I had the ford racing 90mm in my hands and sent it back. Accufab is coming out with an 85mm that outflows the current 90mm they made for Ford and no spacer required using the oem throttle body motor.
Accufab? $900I am considering the Boss piston/rod combo and Boss crank, for the RPM longevity.
What's the msrp going to be on the Accufab TB?
Thanks for the info if it is a Coyote set up.
