Tiddies
life in the slow lane
got my final numbers.
572 hp and 463 tq. its probably a little less because they took out some timing due to a fuel pump issue. i need to get a fuel pump because mine got maxed out at 5500 RPM.
video:
dyno sheet:
mods are:
built motor (9.4 CR)
comp cams 127350's
2.3 Whipple 3.00 pulley (15 psi)
black diamond monoblade throttle body
10% OD crank pulley
kooks long tube headers
corsa mufflers
4.10 gears
video:
dyno sheet:
mods are:
comp cams 127350's
10% OD crank pulley
corsa mufflers
4.10 gears
