DoctorQ
- Joined
- Sep 1, 2007
- Posts
- 37
- Reaction score
- 0
I'm getting ready to install a wideband setup (either Innovate LC-1 or PLX SM-AFR). Planning on staying NA, and only performance mod so far is a C&L Street CAI. Also plan on running with cats, so I'll leave 4 OEM O2 sensors as is (communicating w/ PCM) and will have a new bung welded in pre-cat. Right now, leaning to installing wideband O2 on driver's side, but wasn't sure if there's adequate room... if not, I'll put on passenger side. Question: anyone who has done this, do you HAVE to drop the H-pipe to weld in new pre-cat bung, or can a "knowledgeable" exhaust shop weld in new bung without dropping H-pipe? I'd like to install at either the 10 o-clock or 2 o-clock position, so wasn't sure if there was room to do this without pulling H. Thx.
