Wiring confusion
Monkeyporn
Hi Boys & Girls I need some help with wiring up my new valance foglight. I just had the Roush Front Facia installed and I'm about to wire the lights up. Now the Roush kit came with a switch and relays but I don't want to use those as I want all 6 light to work at once. SO my question is it as simple as splicing the Roush fogs into my grill fogs ? OK you smart electrical brains out there lets hear what I must do and please make it simple I'm a nuts and bolts kinda girl wiring just not my thing.
bambam 06
It is illegal in most states to have all those lights on at the same time.
DieHarder
That's probably the simplest way however running 6 lights up front is illegal in most all states. If you do suggest using part of the kit and switches/relays to allow you to run them safely and turn on/off the additional lights only when you need them. Without seeing the wiring schematic it's tough to tell how to wire it.
Here's a wiring diagram for the foglights: https://iihs.net/fsm/?d=40&f=Fog Lamps.pdf
Monkeyporn
Yes I known and I don't care thanks for calling next caller your on the air.
Bam bam sorry if I was Salty I didn't mean to be but I guess I'm tired of the first thing someone brings up anytime someone mentions running 6 lights is how it's illegal. I think everyone knowns it's illegal and those that are asking how to do it intend to do it anyway. In my case its more for the effect of how it looks see I'm retired and don't drive at night often at all so the changes of me being pulled over for 6 lights is in the infinitesimal. Again forgive any bite my comment may have left, I'm sorry.
Whpony96
Idaho
You will be fine wiring both sets of fogs to work together. Just switch both seat of fogs out to from Halogen to LED to prevent to much power draw on the OEM harness. If you don't there is a good change your gonna melt the OEM wiring harness, relay, and junction box.
