WTT: 2000 Saleen S281 vert, 42K, Fully Built, Turbo, 6spd, etc...
Just putting it out there, and giving this a whirl, if nothing catches my eye, I will just keep this one.
I am really looking for:
1) C6, fine with higher miles, stock or modded (obviously prefer modded)
2) a built C5 FRC or Z06, no verts please, The more mods the better
3) CTS-V
4) SRT8 Jeep
5) a built 05+ Mustang
Only looking at '00 and up cars please
I AM NOT looking to put any cash up for trade, straight up deal or your car plus cash (obviously will depend on the trade)
[email protected]
Located in Southern NJ 08091
Link to pic album, in case pic links go down (due to photobucket bandwidth)
http://s360.photobucket.com/albums/oo45/stand66/2000 Saleen/
And finally, the details on mine:
2000 Ford Mustang Saleen Vert, Fully Built, Turbo
Build number: 00-0703
Laser Red Metallic ext
Black top
Charcoal int
Silver Stripes
42,000 miles
Modifications:
Motor:
MMR 900 shortblock inc:
Cast Iron 2004 Cobra Block, torque plate bored and honed
4340 Forged 3.543 stroke Cobra Crankshaft w/micro polished journals at no extra charge
4340 5.933 MMR 900HP H-beam Rods w/ARP rod bolts (rods are shotpeened, magnafluxed and weight matched )
New Forged Manley pistons
Speed Pro file fit rings
Clevite tri-metal Rod and ACL Performance Main bearings
ARP Main Studs
ARP Head Studs
High Volume oil pump
New timing chain, guides, lifters, timing gears, etc
Felpro head gaskets
ATI balancer
Trick Flow Twisted Wedge Heads 185cc
Comp cams Stage 2 cams
Comp cams spings
Edelbrock Vic Jr intake
PPI plenum
BBK Throttle Body
SCT BA3000 MAF
EGR delete
Fuel System:
Edelbrock fuel rails
60lb injectors
Aeromotive fuel lines
Dual GT pumps
Dual fuel pump hat
03 Cobra tank
Power Adder:
Custom made (Dynospeed Racing) Turbo kit inc:
GT4088 dual ball bearing, water cooled turbo
Mild steel headers, 4" downpipe
Greddy BOV
Tial Wastegate
All V band clamps
Transmission:
Viper Spec T-56
26 spline input shaft
Aluminum driveshaft
Spec stage 3 plus clutch
Spec aluminum flywheel
B&M short shifter
Rear:
Welded axle tubes
3.27 gears
Brakes:
Brembo calipers and 13" slotted rotors in front
Stock rear brakes
Suspension:
Front inc
UPR K member and A Arms
Saleen/Bilstien N2 struts
UPR coilovers with 12"/250lb springs
UPR caster/camber plates
Steeda subframe connectors
Rear inc
Saleen/Bilstien N2 shocks
Saleen/Eibach progressive springs
Exhaust:
Single Dynomax muffler dumped before rear
(I also have a full correct Saleen/Magnaflow catback that can be included)
Wheels/Tires:
Saleen 18x9 front with 265/35/18
Saleen 18x10 rear with 315/35/18 Mickey Thompson DR's
Appearance:
All Saleen S281 items inc front bumper, side skirts, side vents, rear bumper, wing, styling bar, gauges, etc
Cervini Cobra R hood
Misc:
Dual KB boost a pumps
KB boost a spark
New clutch cable
New FPDM's
Greddy boost controller
All new A/C parts
Autometer wideband air/fuel gauge
Autometer Boost Gauge
Raptor shift light
Kenwood CDA 9855 CD player
Performance:
591rwhp @ 13lbs of boost (street tune)
660rwhp 680tq @18lbs of boost at 5000RPM with leaking throttle body (race tune)
Have receipts for over $20K in parts alone, easy.
The car is not "perfect" (cosmetically- scratches, some chips, etc...mechanically its perfect), but it shows very nicely and its a beast.
I also just installed dual Aeroforce Interceptor gauges on either side of the steering wheel
As well as replaced the stock seats (which are seen in most pics, running pony) with 06 Saleen seats.
Have not put back seat in yet, haven't decided on rear set or doing a delete. Don't mind how dirty it is in the pics with new seats please.....
Pics:
NEW SEATS:
3) CTS-V
4) SRT8 Jeep
[email protected]
Black top
Charcoal int
Silver Stripes
42,000 miles
Modifications:
Motor:
ARP Main Studs
ARP Head Studs
Felpro head gaskets
ATI balancer
Comp cams spings
PPI plenum
BBK Throttle Body
SCT BA3000 MAF
EGR delete
Fuel System:
60lb injectors
Dual GT pumps
Dual fuel pump hat
03 Cobra tank
Power Adder:
Greddy BOV
Tial Wastegate
All V band clamps
Transmission:
Viper Spec T-56
Aluminum driveshaft
B&M short shifter
Rear:
Welded axle tubes
3.27 gears
Brakes:
Stock rear brakes
Suspension:
Front inc
Rear inc
Exhaust:
Wheels/Tires:
Appearance:
Misc:
KB boost a spark
New clutch cable
New FPDM's
All new A/C parts
Raptor shift light
Performance:
Pics:
NEW SEATS:
