2005 GT Donut gasket?
Josh E
Hey I keep having an exhaust leak from my bbk shorty headers down to my H pipe. Is there some sort of donut gasket I can fit inbetween the two to prevent this leak from coming back?? If so what size?
I have a 2005 GT
Links would be best
Thanks!
teeje
Ohio
I have a 2005 GT
Links would be best
Thanks!
Remove, clean and use high temp copper rtv. Let dry for a few hours before running then start up. Let the car run for a little bit as the exhaust temp will help cure it the rest of the way.
Sent from my SM-N986U using Tapatalk
Bbk headers are notorious for this. Copper rtv like mentioned above is your best bet. But a bead on both ends spread around and let it set up for 20-30mins then reinstall.
Iceman62
Bullitt 6005
NE
^^^Yep^^^
HT Silicone (aka "liquid copper") works magic on exhausts. Probably the best/cheapest solution too.
Fotoman
I'm having the same exact issue on my 2005 GT with BBK Shorty headers.
That's a Great idea and I'll give that a try Thank You.
Also try replacing the POS flange studs that come with the BBK headers
with a set of Dorman # 03129
