Jake Schmale
Hey everyone, I’ve decided to get a set of cams and purchased a set of comp Mutha Thumpr 127020 cams. I’m not really worried about sound as much as performance. I’ve read these can increase power up to 25+ with the right supporting modifications. So is anyone using these cams? If so how do you like them. A guy at jegs tried talking me into the Lunati voodoo part #21270704 cams but I purchased these instead. Hopefully I made the right decision. The only difference between these two cams was the lobe separation angle 116 vs 109 and the lift at 50 which was more on the voodoo cam but it had less overall duration than the Mutha Thumpr. Both had .450 lift.
