There was a person earlier talking about a boosted car running 4:10's and how he prefers drag radials and that he can hook up so don't fear the gear. A summary of course
He is right that you can hook up, because what he is saying is if his car can do it there will be no issue with the 5.0's, he is using torque multiplication as an example without actually stating it.
Take your torque at the flywheel and multiply it by the first gear ratio and multiply that total by the rear end ration to get your first gear "at the wheel" torque.
Using 400lbs x a first gear ratio of 2.50 to one equals 1000 ft lbs of torque times 3:73 equals 3730 ft lbs of torque going to the two rear wheels. This is not accounting for the torque band curve or driveline loss or tire height modifying the final drive ratio...just numbers.
So using the 5.0 gears in a 6spd standard vs 4.6 and 5spd
5.0
390ft lbs x 3.66 = 1427.40 x 4:10 = 5852 final torque output
4.6 (stock 2010) 325ft lbs x 3.38 = 1098.5 x 4:10 = 4503 final torque output
blown 4.6 assuming 400TQ Roush 400ft lbs x 3.38 = 1352 x 4:10 = 5543 FTO
blown 4.6 assuming 475TQ Whipple 475ft lbs x 3.38 = 1605 x 4:10 = 6582 FTO
If he can hook up 700 more final torque output, then you can run 4:10's in a 5.0 without issue....
That being said I had a 2007 GT with 4:30's no blower and 1st gear was uselessly short on factory height street tires.
A blown 5.0??
Scary!
