changing injectors
Megamach1975
France
hi is there an advantage to changing the original injectors on a 2013 GT?? with PMAS and boss ported intake manifold???
THANKS
AHaze
Edmonton, AB
I'd guess unlikely. If you want to know for sure, datalog a full throttle pull and record injector duty cycle vs RPM. I've generally heard keeping IDC below 85% is ideal. I probably wouldn't bother putting bigger injectors in unless it's going past 90% for a significant chunk of the rev range or 95% at any point though.
Megamach1975
France
cool thank’s
so are there injectors with the original flow rate but which are better than the original ones?? better brands?? ford performance?? which improve efficiency?
lwarrior1016
mississippi
The stock coyote injectors are 34lbs and work very well. You’ll gain nothing by changing them. Don’t swap injectors until power levels require it.
