Coyote swap issues.....
bfarmer
2008 gen2 Coyote swap with mt82. Speedometer doesn't work-it did work with the tr3650 but since the mt82 uses a different sensor it doesn't work now. AC doesn't work and factory Tach doesn't work. Has anyone used the Dakota Digital SGI100
Gen 2 pcm does not work with 05-09 cluster.
You have two options:
Gen 1 pcm - requires gen 1 timing components
Aftermarket cluster, which I have no experience with.
bfarmer
Yes, I looked through the pinned threads, I have seen people using the dakota digital adapter, even dakots tech support says they have hearrd of it being used, they just dont have any specifics of it.
