SteelPulse
the passenger headlight turns on sometimes and sometimes it doesn't but the led strips still work fine, i installed the aftermarket headlights on my stock 2011 mustang what could the cause be?
halogensHIDs?
we’re the led strips also flickering low while they were messed up?I would take the connector off; turn the headlight switch to "On" and check for 12v with a DVM. If working bend and pull on the wiring to see if you lose 12v. Not too long ago I had an intermittent short in one pair (12v/gnd). Stripped the tape back and replaced the bad section; works fine now.
