V
VSOP
Guest
One our body does not really allow a huge rear tire making it hard for lots of HP on a fully streetable tire. Then you have the added cooling issues making that much power that its good to upgrade a radiator and heat exchanger/ic.So going back to the original post it's not the fact that power cant be made with these motors they can make the power but that extra power comes at a substantial price with all the other supporting mods. I was begging to think that these motors were some how handicapped when compared to other mod motors. The 3V heads are supposed to flow just as good as the 4v or close, the alu blocks aren't shabby either.
I know that the input shafts in the tranny are weak, the DS, needs to be replaced, stock clutch is only rated at 380ftq, differential and axles should also get swapped. Supporting suspension mods like LCA, UCA, Axle brace etc.. What's left? I mean if all these things have been replaced, why not crank up the boost a little? I guess one huge problem is traction if you cant get traction on the street with 500hp then what's the point of going for 700hp on the street.
then you have to address your driveline.. etc etc..
Most guys run a lower power street tune and a race gas tune for the track. As race gas is not an option for most on a DD.
