Thatblack03
Hey guys, so I'm in the middle of a 4.6 3v build and need suggestions on a rotating assembly.
![Screenshot_20240701_161537_Gallery.jpg Screenshot_20240701_161537_Gallery.jpg](https://www.s197forum.com/data/attachments/74/74169-f6c14bd3df5877077406933fbe0f734e.jpg)
The goal is to make 650whp on pump 93 with the ability to go 850whp on e85. It's gonna be a big single turbo (88mm) setup, so I'd like to stroke it for the extra low end power for when I'm not in boost. Unsure of what direction to take. Should I go for a 5.3 build? 5.0 build? 4.75?
I'm planning on a 10.2:1 compression ratio with a MMR 5.0 stroker kit right now. That'd be Manley forged steel 8 bolt crank, Manley H Beams, and .020 over Manley pistons.
I'm gonna be revving very high for a 3v at 8500 rpm, so I need to know if this rotating assembly and stroke will take the abuse and if not, which one would. Before you ask, yes. I did mean to type 8k rpm. I'll be running Jesel followers, Jesel solid adjustable lash adjusters, Comp 26125-24 .650 lift springs, and a set of Comp 127650 cams. I'm thinking the limiting factor will be head flow, which a little boost can fix.
Appreciate any help here, I'm pretty clueless when it comes to engine building. I'm not opposed to buying everything separately, but I would prefer a kit.
