Just putting this out there -- there is a possibility that it is designed to deflect air towards the radiator. I only say that because I had a 1984 Trans Am with the aero package, and it had an air dam similar to, but larger than this one. It came loose and fell off on an expressway. The next day, on the same expressway, the car overheated to the point where I had to pull off and shut it down. After cooling for an hour, I nursed it the few miles back home. As it turned out, the air dam was an integral part of the cooling system. I have a 2014 GT/CS, but can't get under it to assess it right now. If you've been driving the car without higher than normal cylinder head temperatures, you're probably alright.
