More headlights
Victorslik
NTX
Can anybody educate me a little on the headlights I have attached images for. Installed in the slightly blinged out 07 GT I recently bought. Closest I can can find to a comparable assembly available today is the "DRL Projector Headlights; Chrome Housing; Clear Lens" available here https://www.americanmuscle.com/raxiom-drl-headlight-chrome-0509.html from AM. I've used a mirror to look for brand names and all I can find is a sticker with a lot of oriental symbols and a reference to being 12V powered. Are they Raxiom's or an import copy? Is this consistent with "Raxiom's"? There website seems to describe them as being "light bar DRL's" and I've read through the install instructions and honestly it seems rather incomplete with no troubleshooting or maintenance info provided. My issue is that a couple of the light bars on one side don't light up and as a secondary(very minor) issue is that these light bars don't function as DRL's. I only find one connector for each assembly and it closely resembles the factory socket on my '08. I'm guessing these are not serviceable and if one or more light bars cease to light up then they are not repairable.These came installed in a really nice low mileage ride purchased recently from a Ford dealer so contacting the original owner is not an option. I am not married to these but they are nice enough that if I can make them work properly I'd just as soon do so. If not, based on all the issues others have with after-market headlamps, I'd just as soon go back to stock using the best lamps and adjustments I can attain. I sure hope this hasn't been covered a blue million times in other posts or forums. I've spent considerable time searching with no good results. Thanks
Victorslik
NTX
looking back at the AM listing for the Raxiom's I may have been remembering wrong and the headlamp sockets are not similar to the factory 08's, I may be confusing them with the fog light sockets. Tomorrow going to pull the bumper cover and remove the RH assembly. The listing makes it appear as they can be disassembled to some degree and there may be another set of leads that power the LED's. If anybody as has already been down this same road and can comment on whether or not they are serviceable it would be appreciated. One light bar on the RH side lights up other 2 don't. From what I've seen so far, mine may be exactly like or actually Raxioms. Thanks again.
Victorslik
NTX
the raxiom reference is just for reference on what they appear to be. If they are just another troublesome junk headlight, that would be useful to know. At $500/set I'd more likely refer to them expensive #&*%*&@ junk. on the other hand they aren't bad to look at if they can be made to work right that would be great, but if just a waste of time, I'd rather not waste the time and just order some stock replacements.
Victorslik
NTX
Well, apparently, nobody here has cared enough for that style assembly to find out the answer to my question, so I tore it all apart and now have the answers I was seeking. Thanks to all who refrained from offering responses I wasn't soliciting.
I'm liking 07 Boss's "color match" idea. Did you dis-assemble and reuse the lenses or are new seperate lens/covers available? I have a set of really faded/aged assemblies I saved from a previous ride. Thinking I'd like to take a stab at color matching them. I did remove the lens from the raxiom style shown above. It was a rather tedious pain, but if the stockers come apart in the same way(heat gun & scrapers) I think I'm going to give it a shot. As I said not married to what I've got although I like the light bar effect.
07 Boss
Sin City
I pulled the stock ones apart and painted them. There are two different manufacturers for our headlights and one uses a glue that can be removed with heat. The other I could not get apart. So it may be a crap shoot on getting them apart but worth the try if they are just sitting there. If anything the ones I could not get apart did not have that little black cap that hangs down over the bulb. The one pictured that were successful were the ones with the black cap, I just removed it.
drwells42
Central New Jersey
Hi Everyone.
I need to replace my headlight housings, as the current ones are hopelessly broken.
I generally like "07 Boss"' idea of painting the housings, though I'm not absolutely opposed to aftermarket. I might have to ask for some painting/masking tips.
My big question is what are good quality replacements? Looks like most of the housings I see online are "aftermarket" specials, e.g. Raxiom, and some of these don't have the best reputation.
Does anyone have suggestions on which ones are good and which ones to avoid?
DRW
Iceman62
Bullitt 6005
NE
Any salvage yards in your area to do a scavenger hunt?
You will need to bake the light in an oven to soften the butyl that seals the lens so you can remove it if you want to service those leds. I did it to add halos and it is not really that difficult. Just don't heat it too high and melt it! You can find details online.
ShelbySteve
Hi Everyone.
DRW
I just ordered a full retrofit projector kit from the retrofit source and ordered new TYC housings from Rockauto. Going to retrofit them myself and paint the entire housing flat black with switchback shrouds. Everything new and top of the line (as far as I know) has me in about $650. All the “upgrades” on am and elsewhere looked cheap and even still comes with halogen bulbs. If you want a cheaper option with oem housing look into the morimoto 2 stroke 3.0 LED’s as they’re 100% better than stock with a good oem beam pattern.
drwells42
Central New Jersey
I'm probably not going to go as far as you are. I'm mostly going to just replace them. I took a look at the TYC housings you suggested, and they seem reasonable to me. What do you like about them?
That said, I still like 07 Boss' suggestion about painting them, assuming that this is practical. I'd have to figure out how to get the covers off and do the masking.
DRW
ShelbySteve
DRW
I like that they’re CAPA certified and they don’t have that metal piece over the bulbs (some are black and some are chrome). I got my TYC in the mail today and they look very good. Get some morimoto 2stroke LED’s and keep the factory housing. Great light output and beam pattern. Pic is my 2stroke 3.0’s in oem housing.
drwells42
Central New Jersey
,I like that they’re CAPA certified and they don’t have that metal piece over the bulbs (some are black and some are chrome). I got my TYC in the mail today and they look very good. Get some morimoto 2stroke LED’s and keep the factory housing. Great light output and beam pattern. Pic is my 2stroke 3.0’s in oem housing.
I looked up the CAPA certification. It seems like a good idea, but I noticed that most of the manufacturers are in Taiwan. Might be better than some of the alternatives, though. Anyhow, the TYC housings are the current front-runners. The Morimoto bulbs seem expensive, and may have to wait for another day.
I'm still hoping that 07 Boss will chime in with advice about masking and painting.
DRW
San Tan Valley, Arizona
I have those housings and the HID projector retrofit as well. They look great tinted but my car has a lot of black accents so tinted on mine looks good. You have to decide for yourself if you want clear or tinted housings depending on your color / theme.
07 Boss
Sin City
DRW
I used heat. A good heat gun and take your time. I started on a corner and heated it up with the heat gun. Worked a small spatula in and then just worked it all the way around. Now I think I mentioned that one set I did was a fail and could not get the lenses off. This set of headlights did not have the little cap that hangs over the bulb. The ones I was able to get the lense off of had the little cap over the bulb but I ended up cutting it off when I had them apart. As far as painting I did a standard adhesive promoter primer, couple of coats of color and then a couple of clear. I get my paint from automotivetouchup.com. They will mix your factory color and put it in aerosol cans for ya. Anyways I used a small bead of windshield adhesive to reattach the lenses.
ShelbySteve
Where did you order the housings that you could get the lense off of? The TYC housings have to be permaseal as I already ruined a housing giving it hell to get it off after trying several temps and times in the oven. I see them on eBay with the metal flaps.
