I was in the trunk trying to track down a creaking noise that is coming from the right rear. Thought it was from a loose upper shock nut because it was indeed loose. After tightening it, I discovered it is actually from the Steeda Rear Chassis X-Brace, specifically the bar that goes to the right rear shock. Attached are two photos showing each upper shock nuts. The left rear isn't nearly as compressed as the right rear yet the noise is coming from the right side. Could the noise be from a bad weld in the brace itself? Should I try greasing the bushings?
