So if I were to plan an engine build, and I could find a Lincoln Mk VIII for cheap, that would be the source for a Tekside block? Do the cylinder iners allow for boringo out? What do y'all estimate would be the maximum displacement I could acheive by boring the block and using a stroker kit when building the engine? The reason I ask is I'd rather have more cubes and remain NA.....
Ahh, the old bore and stroke debate...
I'll try to stay out of the theology and just state my observations of industry "best practice"...
Going beyond ~300 cid generally requires bore and stroke and thus re-sleeving the engine (see
www.vtengines.com)... They get out to 324...
The ~300 cid engines are generally all stroke - for example MMR shows 3.552 bore and 3.750 stroke (vs stock 3.552x3.543). The Livernois and JDM setup are similar from what I recall, but their numbers were harder to find when I typed this...
VT shows a 302 stroker with "stock" bore as well...
Boring out beyond the typical rebuild/resurface weakens the walls which is why VT re-sleeves for the 324...
Stroking is not risk free - you are likely to get some piston slap unless you are extraordinarily careful and many will tell you that a stroked engine will not last as long as a result - that said, you would not be the first/only to do it...
Depends on what you goal is as to whether you _need_ to do it... With head work, cams, exhaust and a bump in compression, I don't see any issue taking the 4.6 to 400HP or beyond... N/A of course requires a little more finesse and planning than F/I to get to that range...
p.s. looks like thump beat me too it and as always used far fewer words ;-)
