Shaker 1000 weird problem
Status
Not open for further replies.
jake_zx2
So, have a weird problem with my shaker 1000 sound system. This just popped out of nowhere, I don't recall when exactly it happened or anything that may have lead up to it. So, basically, everything in my car works perfectly the way it should except the rear subs. Front subs still work, all fuses in the engine bay and passenger side kick panel are good, and I still have the "shaker" option in the radio menu. Could it be that both the amps just randomly fried themselves, or is there some fusebox I'm missing? Thanks!
08MustangDude
Resident Fuktard
Rear subs are FOUR amplifiers on a rack, one for each voice coil in the speakers.
Fronts are two amps, also dual channel.
IF the rears are not working, check power to the amp rack.
i would hope 15 months later he solved his issue
Iceman62
Bullitt 6005
NE
Another "one & done" + zombie thread to boot. Someone, smarter than me, shoud create a script to run where they can purge these old threads from the db.
Status
