You have no idea... My JPC/RGR 3V motor is always at 100 psi oil pressure at idle!!!!
Scavenger pump will be awesome but I would not be surprised if his (OP) turbo seal is already toast. I have 0 smoke on my car other than a very small exhaust amount when I leave the line off the trans brake at full power. A little 'puff' then but other than that, I never see smoke anywhere after the scavenger pump.
It also makes a HUGE difference where the turbo and scavenger pump is mounted in relation to the pan and feed lines.
