Young Punk Build Volume IV - The game needs change & I'm the mother *@#%en cashier
RetroGT2006
06 S197 Member
Florida
Why wouldnt you just sell your mustang and buy the 5.0. It couldnt have been that much more, and the warranty would pay for the difference. Cool build and all but i just bought a 2011 gt with only 9,000 miles for $28,000. You should have dont that.
haha jackass, you should have probably looked up all his threads, maybe then you'll know why he kept it and did the swap.... :dead2:
Daniel Day
Resident psychopath
Newnan, GA
Hahahahahahahahahahahahahahaha! I seriously hope you are joking. If not, I suggest you go back and READ this entire thread. :hammer:
gil_t2
Love Nitro in the Morning
Northern Va
Since you are new, i am not going to call you a F****fool, Read the complete thread and you will answer your own question.
blue streak
Hendersonville, TN
I would have shot myself in the foot before I made that post here. Much less painful.. This guy needs to go buy some underglow and spray paint his interior, that way he will keep his factory warranty lol.
Fallenauthority
La Plata, MD
Its a shame you paid so much for someones sloppy seconds.
CandyRedGT
Illinois
^^^^ Grfeat reply!!!! This thread is awesome!!! Full of fantastic info on the swap!! Best part...he did it himself..not a factory built car!! JMO..
Matt D
S197 Pilot
Toronto,Canada
Ok so talking to a few guys as of lately and kept mentioning this thread but I relized I havn't posted on it in forever.
For all the guys telling me I should of bought a 2011.... you have to relize the car it's Self has all the money tied into it. I spent alot of time with this car and to be honest people have offered to buy it countless times at the track. I would have to be crazy to sell this car, after I all I have been through. As other members already mentioned my main reasons for doing the swap. Little back ground from this past season.
After florida I did the rear end , shortened it by 1" on each side put the rear drag brakes on. Upr adjustable perches with qa1 springs. I fought a bunch of stupid issues. I was ither bogging the car or spinning. I was hitting 10.9-11.0's most of the weekends but I felt the clutch was on it's way out. I bought a ACT set up with lightweight flywheel. Long story short I had to pull the trans out 4 times (the clutch would not disengage under full load) The clutch fingers were going so far in they were touching the Disc. In the end it was all junk.... finally I said screw it.. stock flywheel and dual friction. First pass off the trailer 10.97. I am very happy with the dual friction! I finally started getting the hang of the car near the end of the season best of 10.85 @ 124 spinning to a 1.50 sixty foot.
I feel the 3.35 first gear in the 3650 is hurting me on the 26x10 Tires. I learned alot this season which is only going to help next year. Sooooooooooooo the plan. I need a Trans... my 3650 is getting notchy at high rpm and it's making me hold the clutch in a bit longer inbetween gears causing me to loose time. This winter I want to put a Face plated TKO 600. This will require a bunch of parts that add to the cost... I will have a 5th gear still so I can still street drive the car. I feel this will make a huge gain for the car. I will be putting an alum flywheel in it at the same time to knock 8lbs off the crank will make a huge differnce.
I was going to tear into the motor but I still have to do some more testing with the stock long block. I feel mid 10's is hiding in there. I did find some more mid range power with the vct aswell.
Here are some shots through out the season
Shitty pic but one of the best Launches I had with the car, had 2nd gear issues in the air :mad2: Even more reason for the new trans :roflmao:
Holeshot messed up on my rear wheels. Suppose to be all black but sent the barrels polished. Since I was out with the car everyweekend I had to drill them and get racing. I will switch them out this winter to all black. These are now 6.5 BS with no spacer (because of the drag brakes)
Street Trim
My Best friends Novi 2200'd GT (11.1's on Drag radials over 3500lbs stock bottom end stock heads 580 at the wheels)
Matt D
S197 Pilot
Toronto,Canada
For Spring break I want to switch and take some parts off to meet NMRA Factory Stock trim and enter Factory Stock for the first time on shitty 275 BFG radials :roflmao: I really want to have some heads up fun action. After spring break come home switch everything back and shoot for mid to low 10's.
New build thread will be coming next few months
fhlh
Grabber? Don't Know Her!
Houston
shoulda bought a 2011?
Why, you got the 5.0, the better american built trans and much better looks.
The TKO600 is just going to solidify the deal.
You have one of the best s197's on this forum IMHO.
Keep up the good work!
tigerhonaker
TN
Awesome ride and Great pictures you have taken.
tigerhonaker
