tmcolegr
It's All About the Build
For quite a while now I have been curious to know if BMR's new CB004 Chassis Brace/Radiator Support would fit my 2005 S197. I am currently using BMR's KM011 K-member (1/2" Lowered Motor Mounts with Standard Rack Mounts) and RS002 Radiator Support. The RS002 won't accomodate the new CB004 Chassis Brace/Radiator Support as it doesn't have Front Sway Bar (which I don't use) or Chassis Brace/Radiator Support mounting points. Then I ran across this thread and this post
So after discussing my concerns with Kelly @ BMR, I went ahead and swapped out the existing RS002 Radiator Support with the new RS003 Radiator Support (which does have the Front Sway Bar and Chassis Brace/Radiator Support mounts) using 2 new lower radiator isolators (OEM part# XW4Z-8124-AA).
I was pleased to find the CB004 Chassis Brace/Radiator Support fits perfectly (when combined with the RS003 Radiator Support and KM011 K-member) in the 2005 S197. Absolutely no fitment issues.
I was able to install the new RS003 & CB004 in less than 1 hour. Couldn't be happier with the results. Here's a few pictures of the finished product:
PS: Notice the open access to the oil filter and harmonic balancer. Also no interference issues with the power steering hoses.
For those of you wanting to retain the OEM lower splash shield, as I do, this is a very easy modification. Merely trim the lower splash shield to fit around the Chassis Brace/Radiator Support mounting points, drill (2) additional 3/16" holes and secure the splash shield to the Radiator Support using (3) 8" tie straps.
